303 baler tire size
Message Reverse Sort Order
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Topic: 303 baler tire size
    Posted: 21 Jun 2022 at 10:13pm
Thanks much. Will see what's available locally!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 10:18pm
The left side tire is 6.40 x 15 6 ply, the right side is 5.90 x 15 4 ply. HTH , Tracy
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 8:34am
I'll see if I have a manual when I get home tonight, if you don't have an answer by then
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2022 at 10:07pm
I think it’s 6.7 and 5.5 but not sure
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2022 at 9:49pm
Will try to remember to check tomorrow. I also remember my dad had his set up with a dual wheel on the heavy side
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2022 at 8:31pm
There are two different sizes on the baler. I don't have my manual handy. The tire under the bale chamber is heavier than feeder side. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2022 at 7:33pm
What size tires were originally installed on a 303 square baler?
