301k engine stator wires
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: 301k engine stator wires
    Posted: 29 May 2020 at 4:55pm
I'm replacing my 12 hp Kohler engine I have an extra wire coming from behind the fly wheel or should say from the stater and a wire from the voltage rectifier.  Any ideas where to tie these wires into the  system?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 9:04pm
typically there are two wires from the stator - alternator ( normally white) that go to the rectifier that changes the AC current to a DC voltage output...... Then you have a module for the spark....  ??
Edited by steve(ill) - 29 May 2020 at 9:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 6:11am
like Steve showsandtells... 2 wires from stator to rectifier/voltage regulator module. A picture would help me. I had 4 LGT125s, so same 12HP 301k engine....
jay
This page was generated in 0.039 seconds.
