301 turbo ??’s
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Topic: 301 turbo ??’s
    Posted: 24 Jan 2018 at 3:50pm
Installing a turbo on my 185, looking into a hx30 from a 4BT Cummins. Anyone install one of these on a 301? What needs changed? How did it work?
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 5:34pm
Never used a 30 but a 35 works really well with a small exhaust housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 7:24pm
Hx 35 has a 12 cm exh.housing stock? You think a 8 cm exh. Housing would do the trick? I though a hx would be entirely to big, but I’m not a turbo expert. Hx 35’s are plentiful so that would be nice!
99 f-250 7.3 4x4
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 7:45pm
For performance or just farming ? Ran a H1e holset for years of an L10 Cummings . Great performance from 2500 rpm upto 4500 rpm .
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 8:55pm
I farm with it,& pull it at local pulls. This is not a “ puller” bye any means. I want better performance than a crappy T4ob80 will provide.
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 2:26am
12cm wasn't necessary stock depends what it was on. Without more fuel and rpm it may not run it. U going to need something that will run cool for farming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 2:36am
That’s why I was looking into the hx 30 or hx 32. It appears the hx 32 is not very common... the hx 30 has got to be better than the TO4B80... but it havn’t been able to confirm that yet...
99 f-250 7.3 4x4
Allisman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisman01 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 10:28am
I have heard of people using the hx35. Haven't heard any bad about them
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 11:01am
I may be going with a stock rebuilt unit, since I farm with it. When I put a puller together I may go with a hx 35....
99 f-250 7.3 4x4
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 12:48pm
Much will need modified Keep in mind beside what came on a 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 5:57am
That is the main reason i’m Gonna rebuild my stock turbo& use it.
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 8:21pm
We had a Garrett turbo on our 190xt on the farm it was a beast when we turned up the fuel to pull ! Won against some bigger motors .
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 8:44am
the farms 185 has long been retired to farm chore duty as there are no pulls here anymore, however the 301 out of a M2  with the crappy to4b80 with a .58 a/r housing will still pull 180 hp on the dyno with the torque screw turned out.. it has a 220 pump - 4 roller 31mm plungers and (044 stock tips),  we kept after detuning it a tad ... in case an emergency arrived :-)   7020's used the To4 b80 as well.  While not for full out pulling it is probably not a limiting factor until larger lines, tips, and pump are installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 5:55pm
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 5:57pm
Are these ^ the oil access gallows I need to use for the oil lines?
99 f-250 7.3 4x4
Justthemechanic190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justthemechanic190 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 9:05pm
We have an hy35 on our 190 and it works great. Granted we are running 7080 nozzles and have had he pump gone through. But we’ve still used it from time to time in the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justthemechanic190 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 9:08pm
It really wasn’t that hard to put it on either. We bought an adapter on eBay for pretty cheap and then made our own charge pipe. And we just run a k&n style filter on it clamped right on the turbo. We did have to cut a hole in the hood because the exhaust exits towards the rear To keep everything under the hood. You can even take the down pipe flange off the turbo and get a new one from eBay that has a 3” outlet
Edited by Justthemechanic190 - 31 Jan 2018 at 9:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 4:41am
the only outletn i’ve Found is the v band clamp 3” outlet.
99 f-250 7.3 4x4
