301 gasser
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Topic: 301 gasser
    Posted: 19 Mar 2018 at 4:59pm
How much hp can a guy get out of a 301 gasser with JD 7700 carb and cam upgrade @ 3000 rpm ?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 5:57pm
Just a guess, but did the 7700 with 404 ci have approx. 120 HP at 2200 RPM ?  I would think that would be about the max with 100 less cubes and 800 more revs..   Now as for pulling the key would be how much torque at WOT is produced naturally aspirated...... from 90hp at 2200 to 120 at 3000 --- what is that 25+%  tuff to do... be interesting to see if anyone who did increase the hp NA and actually dyno'd the increase...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 6:43pm
Mack is all into the AC gassers, he could help on this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 7:26am
If you're even remotely serious in doing this, change out the gas pistons for used diesel pistons that have had some material removed from the top of them. This would raise the compression up to the 12 to 1 range if done correctly. Eventually the gas pistons may fail anyway.....they did that in a farm tractor all the time.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 8:05am
I have a set of used diesel xt pistons in a box from an overhaul a few years ago.  If you are interested I would give them away you just cover the shipping.  got sleeves too if anyone is doing slightly over bore stuff, I have not idea if anyone is doing that to go up in cubes or just stroking.
NA G301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NA G301 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 7:00pm
we cued not get much more then stock hp @ 3000 rpm (holy carb) tractor had not run for quite awile.When we had 1 7/8  carb installed hyd and pto had been removed to get to 5500 lb ciass.We would like to try running dyno of flywheel  to see how munch we have now
