301 crankshaft
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Topic: 301 crankshaft
    Posted: 08 Jun 2023 at 12:51pm
I have a crankshaft out of an Allis 301 diesel. I haven't had it speced out yet. If it turns out to be in good shape, what is it worth? The opinions so far range from $200 to $1500.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 1:31pm
There's at least 2 cranks for 301 CID engines. Knowing it's part number or what engine model number & serial number may help determine the value.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 9:10pm
Narrow gear or wide?                MACK
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 9:09pm
It's out of an M2 combine engine. The serial # was hard to read, but looked like 109 thousand something. I don't know the difference between narrow and wide gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 9:21pm
First M-2 was 1977, so it would have the wide gear to be able to drive the crankshaft driven oil pump used first on the 200 tractor and later.
