301 and 426 piston sizes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 301 and 426 piston sizes
    Posted: 06 Aug 2017 at 3:26pm
Curious on the sizes of 301 and 426 diesel piston , how different are they by size?Can a 301 block be machined for 426? Just curious
Edited by DougG - 07 Aug 2017 at 5:07pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 4:20pm
301 is 3 7/8" bore, 426 is 4 1/4". Not sure what you're wanting to do, but not sure how you'd make a 301 piston ever come close to working in a 426.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 4:55pm
301 block machined to accept 426 piston, just wild ideas
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 5:43pm
a fairly popular thing to use is case 401 pistons modified for a 301, and custom sleeves. They are 4 1/8" bore. ops heads on here sets up kits. I have a bunch of those pistons that need finished machining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 3:46am
I gottcha, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 12:11pm
From what I've been told, you have to have the top of the case piston machined. I have not done this, yet. Some day I may get around to building my 301, but until then, that is all I know about the piston deal. I'm not making them, or anything like that, so no point in calling me and asking questions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2017 at 3:29pm
I'd say it would take alot of head work to get it to run good as the heads don't flow real great
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2017 at 8:43pm
We have a 4.5 bore with custom sleeves and bored block. That's about the 100%max you can go with a 301 on bore. Have to have a deck plate to keep top of block together. I have started another project with some help it's a 451 case piston that I will all so be running a deck plate it is in the works and on hold. Hopping that the smaller bore will make it live longer.
Iron horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iron horse Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 3:13pm
What all needs done to the pistons or do you have a set done to sell
This page was generated in 0.383 seconds.
