3 pt conversion dimensions.
the3880 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote the3880 Quote  Post ReplyReply Direct Link To This Post Topic: 3 pt conversion dimensions.
    Posted: 13 Nov 2019 at 1:05am
Greetings all.  Planning to fab a three point conversion on my '53 wd45 and I was wondering if someone might have the dimensions like the length and cross section of the bottom arms, length of vertical attachments, location of vertical attachment on the bottom arms and maybe a photo of where youre top link bolts on, and length of the top link.   Many thank yous in Advance.
As an aside not related to the post my machine is about the 300th 45 manufactured.
Edited by the3880 - 13 Nov 2019 at 1:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 7:55am
the3880,
Top link should be a std from any tractor supply store,
The dimension for the hole for the vertical lifts can be about the same dimension as the holes in the lift arms.
if the side lift arms are solid (no adjustable dont make them too long. My guess is about 16 inches is close to what you want.
The center attachment for the top link can be a U shaped bracket with hole:
Center cross piece for drawbar is about 14 inches wide ish?? or about the same width as the Guide that holds the drawbar.
HTH
Sorry I dont have mine here to measure.
Edited by Sugarmaker - 13 Nov 2019 at 7:58am
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 8:19am
Recalling from the past;
Wait until the lower lift arms are positioned in working position before determining the length of top arm.  This being determined by the mounting position and length of lower arms.  I seem to remember 8-10 inches or so(this to mount a one row corn picker on a WD, mid '50's) and a little dusty on details.  Top link was not needed until a carry-all came out of shop fabrication area.  HTH
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 9:25am
Hi.    Check these pictures out.    Ross.
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 10:42am
Would this be an alternative to fabricating one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 10:52am
Sure would!
Location showed- Wasilla AK
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 11:46am
Picture for Modirt's link
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 3:55pm
That's the one I bought. Like the3880, I had visions of fabricating my own. In the end it was far more worth it to just buy that kit. Perfectly satisfied with it!
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 6:31pm
The advantage to this type(the one pictured) 3 point kit, is that it foes not negate the tractor's traction booster draft control, if so equipped...Wink
If it were my tractor, I would prolly search local auctions, where AC stuff is being sold, and pick up an original AC made conversion.  Don't know how plentiful these are, in your area, but around here, they are a few, still.
Here's a link to a picture of the original...
Edited by DiyDave - 13 Nov 2019 at 6:32pm
This page was generated in 0.949 seconds.
