3 point question on 7000
Ksdigger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ksdigger Quote  Post ReplyReply Direct Link To This Post Topic: 3 point question on 7000
    Posted: 25 Feb 2019 at 6:29pm
This is how the 3 point was set up on my 7000. My manual shows the sliding nut on the bottom of the swivel. In the next pic I'm posting I
put the nut on the lower side. What it used to hold it in place? A bolt? There was one in it but it was bent and almost sheared off.
Any help appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ksdigger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 6:31pm
This is how I think it should be. Maybe both?
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 7:12pm
I'll take a picture of mine tomorrow. I don't want to speculate. lol  Tim
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 7:45pm
They used a hardened "picker pin" to hold in place. We took them out when using on 3 pt cultivator and bale carriers. This was on  late 200 and 7000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 7:48pm
Correction, we moved them to lower hole to allow implement to move more.  Your second picture has it installed as from OEM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ksdigger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 7:54pm
KJ, You are saying the second hole down was used as a float position?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 7:26am
That's the way it was designed. In the up position there was zero side to side float. In the lower position it allowed the hitch to float, especially needed with WIDE mounted implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ksdigger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 8:27am
Thanks guys for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 4:55pm
I learned something from this post. Here is how they are set on my 7000.  Tim
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 6:08pm
I have the spacer on top on my 7000. It gives you more 3 pt lift height. I needed that when I used to pull a front fold Deere planter. It got the planter units higher off the ground when in transport position.
This page was generated in 1.043 seconds.
