3 Point hitch issue,,,question
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Topic: 3 Point hitch issue,,,question
    Posted: 25 Feb 2010 at 10:23am
I've noticed that I've got a problem brewin' here on the back of my WD.
From the pictures below, you can see My 3 point hitch pivots are comming out of there sockets, I'm not sure how you go about repairing this?,,,taking suggestions!,,,Thanks!
www.allischalmersmuseum.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 10:31am
Larry - you can see those ends with the swivels balls were welded on your arms.   Replacements are readily available.  Just cut those off and weld new ones on.  Mike
Example:
http://agsupplyonline.com/.sc/ms/cat/Three%20Point%20Hitch--Lift%20Arm%20Weld%20On%20Ends
Edited by Skyhighballoon(MO) - 25 Feb 2010 at 10:35am
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 10:41am
I saw that and wondered if that was the "fix" on this!
Thanks dude!,,I reccon a 7018 low h welding rod would be the right hardness for that,,or should I use 8018?
Two balloon trips at Dales this year (weather permiting)?,,that'll be great!
My kids got a kick outa seeing you last year!,,the've never been around or saw anything like that before!
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 11:32am
7018 would be a good rod to use Larry.  We use it on all the structural stuff here at work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 11:42am
OK,, Thanks Skip!
I know we used it for almost EVERYTHING on railroad cars!
8018 we used on "high pressure" tank car shell repairs, pretty hard rod.
