3 Point Hitch Adapter WD45/D17 IV
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: 3 Point Hitch Adapter WD45/D17 IV
    Posted: 19 Jan 2015 at 6:31pm
I'm kind of thinking out loud here, but can't seem come up with a definite answer. Is there a snap coupler to 3 point adapter that will fit both a WD45 and a D17 Series 4. I want the style that allows the traction booster to work. I understand that I will probably have to fabricate my own top link brackets, but that should be no problem. -Thanks in advance.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2015 at 6:44pm
Look up Tony's Tractors. A sponsor here. Check his web page. He sells them. As far as a unit that works on both a D17 and a '45 ... I can't vouch for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2015 at 6:51pm
If the 17 is a Snap Couple tractor, Yes, there is one that will work on both tractors. If it's a 3 point, I guess you wouldn't need an adapter Wacko
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2015 at 6:58pm
Yes, the D17 would also be factory snap coupler equipped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2015 at 7:09pm
The factory type "Wishbone" Is the one that will do what you want. Easy on and off. AC even had toplink brackets for each tractor.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2015 at 7:11pm
Yes  hitches  will  interchange !!   We   can help.  Tony  1-877-602-3994
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2015 at 5:31pm
Thank you for the information. I'll be giving Tony a call.
Pilot172000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pilot172000 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2015 at 5:53pm
I have the wishbone type.   Chains were holding up the arms so I purchased stabilizer bars and robbed the rest from my dad's 3 point hitch off his 17. They are exactly the same.
Behind every great farm is an orange tractor!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 3:51pm
Does anyone know if there are any dealers in NW Ohio that carry the wishbone style hitches? I haven't gotten a quote from Tony yet, (Closed till Friday) but I would assume I will have $100 in shipping. I would like to save that money if possible, I can drive a long ways for $100. -Thanks
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 4:37pm
Tony can have one drop shipped from the manufacturer right to your front door. So the shipping with be the same as one from a dealer just down the street for your house.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 3:40pm
Interesting, I guess that would mean Tony would be about the cheapest option. Thanks, Don.
tim 52160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 52160 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 10:25am
My biggest problem on my d 17 series 1 isthere top link is a plate that bolts under the seat and the piece that is wellded on the back of it to hold the top link bends and breaks especialy while bushhogging
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 11:24am
Tim, call Jim at OKTractor and get one of these. Then add a length of chain for the top link, so the back end cam come up if it needs to.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 3:59pm
I think this would work for you.
You need to pull from the 'Snap Coupler' for the Traction Booster to work
Gary
http://www.allischalmers.com/forum/forum_posts.asp?TID=100848&title=d17-series-1-3-point-snap-coupler-adapter
This page was generated in 0.186 seconds.
