3 point fitting leaking
D-Rock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-Rock Quote  Post ReplyReply Direct Link To This Post Topic: 3 point fitting leaking
    Posted: 09 Jan 2018 at 10:56am
Hello all,
I have a WD and the fitting that is connected to the 3 point to raise and lower it is leaking badly while the tractor is running. My question is where do you fill the liquid for the 3 point? Also is it hydraulic fluid? I’ll be replacing the fitting and hose but I’m the meantime I don’t want it to run out of fluid.
Thanks in advance!
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 11:16am
Left side, in front of the clutch pedal, inside of the rail.
There is a dip stick there with a tab on top of it.
90* twist to the left and pull it out.
Yes, hydraulic fluid. 821 or its equal.
Edited by Jim Hancock - 09 Jan 2018 at 11:29am
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-Rock Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 11:26am
Perfect thanks.
