3 point cylinders
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Topic: 3 point cylinders
    Posted: 01 May 2021 at 5:45am
Anyone out there have the cylinders for the back of the d19? looking for a pair. I understand that the ones from an XT190 are the same. thanks for any help!
If you choose not to decide you still have made a choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 6:12am
options you've already though of I suppose....
I'm guessing you don't have any, that could be rebuilt ?
Maybe get the specs and buy new ones ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 7:03am
Why not reseal your own ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 10:49am
I tried that but the cylinder bores have rust pits in them and still leak.
kjs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kjs Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 11:19am
There is a place in West Point Ne, Seals and Service that can put a new barrel on them.  They do a lot of work on large and small cylinders.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 8:31pm
A local shop might be able to make new barrels too.  Mine does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 9:48pm
Why would pitted bores matter? The seal is on the piston/ram.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 6:24am
The seal on shaft is only a wiper on the 190 style cylinders.            MACK
