3 point conversion kit D-17
Tankster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tankster Quote  Post ReplyReply Direct Link To This Post Topic: 3 point conversion kit D-17
    Posted: 18 Nov 2015 at 10:53am
I purchased a 1959 D-17 that had a 3 point conversion kit already on the tractor. I then purchased a 3 point hay stabber it fits but
I have not been able to use it when I raise the arms the hay stabber
actually lowers making it so the bale slides off. Any Idea is it the
3 point conversion that isn't adjusted correctly or is it the hay stabber that is the problem. Any suggestions would be greatly appreciated.
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 11:09am
Is it two of three point mount. Mine rest under the arm so a different arm might rest different.
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 11:10am
Sound like your 3rd arm to long to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tankster Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 11:26am
Are you thinking my top connecter is to long ?
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 12:06pm
that's what it sounds like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tankster Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 2:12pm
Thanks I will check it out !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tankster Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 2:13pm
Not sure what you mean ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tankster Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 2:15pm
Not sure what you mean Mintenfarmer??
NV4500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NV4500 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 3:18pm
I think he's talking about the adjustable top link that is in the bracket between your PTO and your seat.
1965 D17 Series IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 4:02pm
I use a separate top link for my pallet fork attachment that I do for other things. its a good old heavy IH link and is easier to adjust under load than the cheapo new ones you get nowadays
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 7:28pm
Adjust the toplink and you will be right on target!---your geometry is off ! lift arms and top link have be set to run parallel when lifting! thanks; ac fleet
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 9:45pm
Top link needs lower on tractor or higher on bale mover.   MACK
This page was generated in 0.523 seconds.
