3 Point Conversion for D17 opinions
Strokendiesel002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Topic: 3 Point Conversion for D17 opinions
    Posted: 13 May 2020 at 4:20pm
Afternoon!
I'm finally ready to buy a conversion kit so I can use some additional implements, and after shopping around I'm a bit surprised at the differences between some of the sellers. I've settled on the drawbar mounted conversion as most say the sway block is preferred over the chain method.
Anyone have any experience with the kits offered through Steiner or OK Tractor? Any others that I should be looking at?
Thanks and I hope everyone is doing well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 5:30pm
I chose 'door #3'.
I've converted my 3PH implemnts to Snap-Coupler.
Ok, I'm NOT a 'real farmer' but I found dealing with 3PH to be a PITFA compared to Snap-Coupler.
Really, the 5' rototiller is a 'hybrid' setup. SC with a top link. The toplink is BOLTED to the rototiller, so after the first adjustment, it NEVER has to be played with. While this cost me a bit in material( adapter and toplink) it saves me BIG $$$ at the chiropractor and time !! Instead of fighting to get 3PH on... 60 seconds and I can till the wife's garden...
Might be an option for you ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 5:45pm
My favorite is always, the OEM "wishbone adapter"  it was engineered, for the tractor, and the traction booster system...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 6:18pm
Thanks fellas
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 6:34pm
A real drawbar would be a "Yes".  Real sway blocks would also be a "Yes".  I think the biggest question for me would be Cat #1 or Cat #2 ??  and will there be implements for both sizes ??  And then, how many 3 point implements will the tractor be handling?? Quite honestly, there are many implements that can have an adapter made to leave on them and utilize the snap-coupler tractor. This is especially true if you can fabricate things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 7:28pm
Dr-
Cat#2 is what I'm told the kits that have the block that get bolted to my existing drawbar are. I only have 1 3 point implement at this point that I would use, however there are multiple implements that I have t opportunity to borrow from time to time. I don't intend on ditching my snap couplers, as if a SC implement shows up locally and reasonably priced for the extent that I'd use it, I would be glad to have it (back blade, scoop, what have you) I have a pull type mower that I use for keeping a trail around the field (long time friend who's actually a farmer mows and bails it) and trails through my land behind the field, but I'd really like to be able to use the 3 point mower I have as well.
One main reason I want the 3 point is to have a bar with 2" & 5/16" ball spanning across for moving the trailers around without constantly getting on and off the tractor. At that point, I may as well just use the truck, but I like running the ole girl :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 7:57pm
re: One main reason I want the 3 point is to have a bar with 2" & 5/16" ball spanning across for moving the trailers
20 years ago...when I got 'Troy', I ditched the loader and made myself a Snap-Coupler 'carryall' using forklift forks and  a 2" receiver. the forks are GREAT at moving heavy things like 3400# logs( not 3600# , I tired....).
 The 2" receiver allows me to sleeve in a 2" ball or 2 5/16" to haul trailers ( I do that a lot....) OR pin in a balless sleeve that I use as a 'drawbar'. That works great at moving my 2000 Gallon empty water tank built on a semi frame.
yet another 'option' ??
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:34pm
I put a 3 point on my D17 I like it. But as mentioned the Allis Snap coupler system is one of the best. I hooked up my 3 Allis plows so easy on the WD45 with the snap coupler, it was just a joy after fighting a std 3 point attachment.
 Not sure where this kit I have came from? It was on the WD45 I got a few years back.
This kit does attach to the drawbar. I made the top link bracket.
Edited by Sugarmaker - 13 May 2020 at 8:49pm
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 7:15am
Bought my wishbone style 3 point from Jim . Works well . It's on my D 15 and it's cat 2 . Only snap coupler implement we have is a 3 bottom plow we never use . Thanks
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:03am
I chose 'door #3'.
I’m an Allis guy but let’s be honest was at best the third best option at the time.   Thankfully most of my tractors are new enough that’s not an issue.   Between snap coupler and traction booster definitely Allis’s biggest design errors.  Makes 3 point the standard was the right move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:12am
You must have the 'charm' to get 3PH implement off and on as I've never had luck, especially on lumpy ground, wet dirt, etc. I don't have a nice level concretet pad to change implements and the old body is saying NOT to push,pull, lift heavy 'things' anymore....
I no longer have the time to waste on 3PH, less than a minute to get tiller on and into the field with NO adjustemnts, NO stress and NO hernia.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:04am
Fellas -
Good thoughts all around. I really do appreciate it!
Jayb - would you be willing to share some pics of that setup?
Chris - thank you for the pics! Is that a special "pulling" drawbar I spied?
I have been thinking about getting another drawbar that I can shorten up after reading and seeing the advantages
Thank you again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:06am
AC - thank you - is Jim OK or Steiner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:08am
Each has it's own design pluses and flaws. A 3-point hitch that doesn't have the "extendable" lower links is difficult to get hitched to many implements. Snap coupler is unique to itself. I'll tell you this, when moldboard plowing, the snap-coupler hitch, on a 3 or 4 bottom fully mounted plow, is superior to a 3-point hitch in rock country.  Almost every rock you hit with a 3pt, you'll shear a bolt or trip a bottom. The snap-coupler hitch allows the plow to be tossed out of the ground sideways in many cases, and avoids damage to the plow. Been there dun that with a 170 and an S4 D17 in the same rocky field with 70 series plows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:26am
Stroken,
That is just a temp draw bar from a WD series tractor I put on to try the 3 point set up. I do have a custom pulling drawbar, (shorter)  for the D17 also.
Good luck with your conversion to 3 point.
I was just running the 272 groomer on the 17 today. The right adjuster had unscrewed out about 4 inches. Guess I need to zip tie that, or wire it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 10:08am
If you need a 3pt get a series IV D17. anything earlier or smaller from and for an Allis Chalmers is a piece of crap. The best option for smaller older tractors is the factory (or a copy) wishbone adapter and hook it onto the equipment first and then attach it to the tractor VIA Snap-Coupler. One great advantage the Snap-Couple has over any other hitch system INCLUDING EVERY 3pt is that when an implement is removed from the tractor, all the adjustments remain as it was last being used. Which makes returning to the task a breeze, no need to spend a few rounds getting the implement adjusted again. 3pt equipment is a great way to ruin your back, pinch your fingers and learn new cuss words.
Edited by PaulB - 15 May 2020 at 9:08pm
John (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 10:27am
I don't think you can beat the Cross Mfg conversion that mounts on the AC snap coupler drawbar.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 11:32am
Sugar Maker  !   That is a  Cross  Draw bar  mounted  hitch ,  Less  the  sway  control.    Tony  .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 12:06pm
Tony,
 Thanks I dont know what the sway control looks like? Maybe I need it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 12:08pm
Jimmy , I bought my 3 point from Jim at OK tractor . Think my son got his from Tony . Might be a good idea to give either one a call ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 12:17pm
Bill(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 2:25pm
I picked up one from Cross Mfg for my CA. Works good.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 3:41pm
it’s sad that the 3 point system won the day. It’s such a pain in the a** to hook up and doesn’t work as well.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:17pm
Twenty five years ago when Dad was buying and selling used tractors and equipment he sold a dozen or more of the ones from Cross Mfg. Never any complaints except from the post office as they would ship them US Mail. Mail carrier would sometimes bring them out in the trunk of his car but often we had to go get them. They were a nice made hitch. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:06am
Removing and reinstalling the drawbar on a 17 is a added pain enough imagine on a 300++ horsepower articulated tractor.  I’m amazed by the color blindness.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:16am
Tom I remember when UPS brought my hitch . I was in my shop behind the house and the driver parked in the street and carried it up . Asked him why he didn't back up the driveway and he said it wasn't that heavy . Pretty heavy to me . Of course they'd lost half of it , which came a few days later. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:33am
As a 15-16 yr old, dropping the drawbar off of an S4 D-17 was easy. Throwing the whole thing back up in there as one unit was a struggle. It was just about as heavy as a 190XT drawbar. Interesting how the 3-point hitch had to evolve into having a quick hitch on it as it got larger and larger. I think the snap-coupler drawbar/weight issues could have been overcome had it been continued on to bigger tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:43am
re: Interesting how the 3-point hitch had to evolve into having a quick hitch on it as it got larger and larger
yeesh, they have them for all the 'little' tractors now too, including my BX23S ! A lot of guys complin though as 'CAT1' implements do NOT fit properly, PTO shafts too long, etc.
I still haven't put the 3PH on it though, lil digger is real useful... and there's always a D-14 nearby !
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 8:54am
I've got one (for a 17) that came on my NF 45. It didn't work well at all. I tried and tried to make it work and finally gave up. I stripped most of it to bare steel and repainted it. Need to get the top-link bracket welded back together and see if I can make this thing work on my 17. Memory seems to be the big problem here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 9:07am
Any add-on 3pt hitch that doesn't utilize the lift latches (or lift arm extenders) will always be a second rate hitch, due to the lack of lifting and lowering height. Also, the top link anchor that has only one hole, makes the hitch hard to adjust to lift and lower properly. On some implements you'll get along fine and others, you'll never be happy.
This page was generated in 0.355 seconds.
