2900 Series Question |
HARVESTMOONPULLER
Topic: 2900 Series QuestionPosted: 01 Feb 2010 at 12:28pm |
Would a 2900 series motor from an L2 bolt into an XT? Got an XT and need a motor
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 792 |
Posted: 01 Feb 2010 at 2:58pm |
yes but you will need the tractors engine rear plate. there might be a few other modifications but thats the main on that i know of.
hope this helps ryan Edited by ryan(IN) - 01 Feb 2010 at 2:59pm |
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3664 |
Posted: 01 Feb 2010 at 6:37pm |
front covers will need to be swapped as well - the biggest problem is the front axle will hit the larger oil pan on the XT - Either find a 200 front hsg or cut and reweld the pivot pin on the axle about 3.5" higher (or whatever the bolt hole distance is on the rear axle support) and add a plate on top of the rear axle support drilling it to fit the holes as the top set will now become the bottom set.
The fan location on some L's will be different and the shroud will have to be modified. Keep the electric fuel shut off - it is neater.
AndyinWI
Joined: 22 Sep 2009 Location: Blue Mounds Points: 416 |
Posted: 01 Feb 2010 at 6:40pm |
You will also need to swap the front cover and if I remember right the cylinder head is different, I swapped one into 7000 a few years ago and i beleive it was a water port that was different, so i swapped the head. andy |
HARVESTMOONPULLER
Posted: 01 Feb 2010 at 6:42pm |
Is there also such thing as a Mark II 2900? I was told the one in the L2 is a Mark II but wasnt sure of that.
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 01 Feb 2010 at 7:24pm |
we have a 2900 engine in a tractor northern ind. 1-800- 254- 3116 call for more info.
