2900 block question
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 2900 block question
    Posted: 22 Jun 2015 at 10:13am
Stopped at local mechanics shop and he is doing an OH on a 190XT. He pointed out that on this 2900 block there is no oil hole for the rear cam bearing to line up with. Are they all that way or this block a fluke?
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 11:08am
That is the way they are. Tell him to not even try to figure out how it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 11:41am
So is it normal to have that bearing fail long before the other cam bearings. This thing had plenty of hours on it, but that bearing looked horrible.
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 12:08pm
No. The front usually looks the worst.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 10:22pm
I was once told they are oiled by magic lol! But I bet what doc said is true if you look at the old bearings. Also, put the new ones in the freezer until right before you install them. Makes it way easier to press them in.
Hurst
1979 Allis Chalmers 7000
5800 Hours
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 10:56pm
once overhauled a 2900 out of a cat scan gen power unit. 12000 hours. The cam lobes were almost flat, lifters were cupped unreal, cam brgs were almost perfect - except front was showing bronze, as stated, magic,,, don't screw with perfection....
cranky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cranky Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2015 at 7:51am
cam bearings rely on oil draining back from rockers to lube bearing journals.it is not pressure fed lube
