28 inch rear wheels |
playsindirt
Joined: 13 Feb 2011 Location: west michigan Points: 159 |
Topic: 28 inch rear wheelsPosted: 14 Jul 2016 at 7:47am |
can I put wd rear wheels on my D-15. I can find used 28 inch rims and tires all day. seems 26 inch are not as common. Thanks.
48G 49B 67D15 35picker allcrop60 1973 rotobaler 49C
Posted: 14 Jul 2016 at 7:52am |
The complete rim and spin-out center will fit a D-15, yes.
DougS
Posted: 14 Jul 2016 at 8:16am |
D-15 should have had 28 inch tires in the first place. What were they thinking?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 14 Jul 2016 at 8:20am |
If there isn't any fender issues that's what I'd do.Have 14.9's on the WD and you can't set wheels in the last notch but don't need that setting anyway.
Posted: 14 Jul 2016 at 8:22am |
That's one of my arguments why a even a D-15 II never really replaced a WD-45 on a 3-16's mounted plow in tough going....less rubber and less engine torque.
Gerald J.
Posted: 14 Jul 2016 at 8:27am |
If the tire has traction the slightly small diameter gives more pull for a given ground speed and engine power. The trade off is the bigger tire often has more area on the ground and so is a bit better at converting torque to pull. Its also affected by weight on the tires, type of tire (bias vs radial, radial always pulls better), engine torque and gear ratios.
A two inch larger rim with the same cross section tire also means the axle housing clears the ground by another inch, handy when cultivating or spraying row crops. Gerald J. |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Posted: 14 Jul 2016 at 9:03am |
The taller rear tires could make it tough to hookup snap coupler equipment. I have 16.9-28's on my WD45, and unless everything's perfect I usually have to jack up the snap coupler hitch 1-2 inch to get inside the bell.
Adam Stratton
Posted: 14 Jul 2016 at 11:48am |
I have 14.9 x 28s on a d15ii and it works just fine for me
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 14 Jul 2016 at 3:47pm |
Make sure you use the rail stops, if the eccentrics don't hold the tires will hit the fenders.
ALLIS EXPRESS!
This year: |
