271 install rear main oil seal
WaltDevore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Topic: 271 install rear main oil seal
    Posted: 18 Jul 2021 at 9:04pm
This drove me crazy all day.  On verge of insanity.  Thought I could gently tap and work it in, but it always goes out of kilter and pops out.  Any recommendations?   Help save a life.  Thanks.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 7:16am
detroit likely has a special tool for that.  you may need to fabricate a disk large enough to contact the entire seal if you dont already have something, where as you can tap in the center and work it on slowly.  i dont know this particular application but sometimes a tool is required because of the seal type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 9:09pm
And it probably is not going to be a flat surface tool. The one on Cat is shallow in center so OD can push on edge of seal flange. It has a steel sleeve which presses on crank and is internal part of seal. Actually presses on 2 areas...inner and outer at the CORRECT dimensions. Can be made but needs to be done right
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 1:48pm
From calling Timken and finding National RD installers on Amazon, I learned the supposedly right one is the National RD314.  Found one on Ebay for 25 bucks.  Sure hope it works.  What a stymie this has been.
Edited by WaltDevore - 03 Aug 2021 at 1:50pm
This page was generated in 0.398 seconds.
