262 in WD45
56allis_msu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56allis_msu Quote  Post ReplyReply Direct Link To This Post Topic: 262 in WD45
    Posted: 07 Nov 2013 at 12:56pm
Gentlemen
I have purchased a 262 out of a gleaner to put in my WD45 super farm puller.  I just wanted to ask if anyone could impart a little knowledge on what all has to be done to get the motor to fit/run right.  I have a set of diesel frame rails if the frame needs to be longer but it seems like I have seen these 262s in the original gas frames with no problem but I could be wrong.  Any list of extra parts and things I'll need to do will be much appreciated.
Thanks!
Ben
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 3:05pm
OK from what I know he will need a wd45 diesel engine backplate. Allis changed the wide front from 3 bolt to 4 bolt for two reasons one was brakeage the other to fit the Diesel. wd45D narrow fronts are there own casting. A friend has one in a converted to gas tractor. The diesel radiator is different. hood longer. you will have governor issues as well, combine will either idle or be wide open. a cockshutt front plate, timing cover, and governor will work. Look for one from a 30. they had a six ball governor that can take more rpms. also get the front pulley and engine mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56allis_msu Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2013 at 3:16pm
bump
