262 head gasket
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Topic: 262 head gasket
    Posted: 09 Aug 2012 at 1:45pm
Where's the best place to get a good quality head gasket set for an early d17 diesel with water pump on the head thanks, Bryan
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:14pm
AGCO
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:23pm
Try Sandy Lake Implement 1-888-252-0656Tongue
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 10:23am
A neighbour rebuilt a D-19 Diesel. One supplier said the head gasket was the same for gas or diesel with a .030. fire ring. Another supplier said the the .030 was for gas and .060 was needed for the diesel. Should be the same for a D-17 diesel. Sleeve standout is very important. Should be  + .0020 to +.0040 not -.0020 to + .0020 as stated in the specs.
Edited by Calvin Schmidt - 10 Aug 2012 at 10:50am
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 10:38am
Originally posted by Calvin Schmidt Calvin Schmidt wrote:
A neighbour rebuilt a D-19 Diesel. One supplier said the head gasket was the same for gas or diesel with a .030. fire ring. Another supplier said the the .030 was for gas and .060 was needed for the diesel. Should be the same for a D-17 diesel. Sleeve standout is very important. Should be  + .020 to +.040 not -.020 to + .020 as stated in the specs.
Calvin means .002 and .004 I think
20-40 thousnadths is a heck of a liner standout.......
should be 2-4 thousandths
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 10:51am
Correction noted and made.  thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 3:24pm
I ended up between the .002 to .004 above on mine. Don't forget that you need a couple special bolts to use as dowels. There are no dowel pins to locate the head and gasket from the factory. I had a couple bolts built up and turned down to fit the holes in the head to locate both the gasket and head.
