262 gas in D19, F questions |
   ChuckLuedtkeSEWI
   Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826  |
      Quote   Reply
     Topic: 262 gas in D19, F questionsPosted: 30 Sep 2012 at 7:22pm  |
Was the gas engine in a D19 and the engine in a Gleaner F essentially the same engine other then the governor?   I've seen numerous people mention to use the Zenith carb off of the combine engine for pulling.   What's the difference between that engine and the one in the D19.   I picked up a Gleaner F engine this summer complete, and was wondering if the hp of that engine is more then my stock D19, and if I would be better off swapping the entire engines out.   Right now I know the head on my D19 engine needs some work, and I was thinking of pulling the head off that one and swapping them, but maybe I should switch out the entire engines.
     1955 WD45 diesel 203322 was my dad's tractor, 1966 D15  23530, 1961 HD3 Crawler 1918, 1966 D17 IV  83495, 1937 WC 41255, 1962 D19 6221
   SteveM C/IL
   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8681  |
      Quote   Reply
     Posted: 30 Sep 2012 at 7:33pm |
I would say essentially the same but not an expert.The combine engine will have a higher advertised HP because they are flwheel rated and tracors are pto rated. HTH Obviously the govs are different.
   Don(MI)
   Joined: 15 Sep 2009 Location: Michigan Points: 3900  |
      Quote   Reply
     Posted: 30 Sep 2012 at 7:49pm |
   I think the Gleaner C had the 262 engine in it.
     Galatians 5:22-24
  "I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!"  |
   SteveM C/IL
      Quote   Reply
     Posted: 30 Sep 2012 at 8:40pm |
C and early F's then F's went to Chevy 292
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
