262 diesel rod bolts |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4030 |
Topic: 262 diesel rod boltsPosted: 04 Jan 2026 at 2:06pm |
need a part number or source for rod bols and nuts the oem part numbers seam to not go any where on the innernet does arp have somthing i am going to order new head studs from arp my origanal block had studs my doner block had bolts. but for now we need to find rod bolts
JosephD17III
Joined: 16 Oct 2025 Location: Neosho, MO Points: 20 |
Posted: 07 Jan 2026 at 8:30pm |
I don't know where to find one, if you have a local tractor graveyard you could try there. Otherwise maybe the more experienced members would know?
HudCo
Posted: 07 Jan 2026 at 10:13pm |
we found enought new ones this morning oems from a few differant dealers but i am going to try and get arps . absolutly no used rod bolts especaliy on these old engines that have probly had a half of dozen in frames
RedHeeler79
Joined: 09 Sep 2023 Location: NE Kansas Points: 230 |
Posted: 08 Jan 2026 at 9:00pm |
Keep us posted on this. If ARP has a replacement, would you let us know? Or post the p/n of the original bolts/nuts, if still available? I’m strongly considering replacing mine before final assembly. Don’t want to take chances after all the headaches it has been getting this far.
HudCo
Posted: 09 Jan 2026 at 10:31pm |
arp is sending me one bolt to see it it will work , it sounds like the nut will end up exactly flush with the end of the bolt. think we will machine the rods and cap just enought to get a full thread past the nut also the grip lenght is about 1/8 longer that shouldent hurt. because thier is only an 1/8 grip in the cap . if it will be ok they have plenty and they cost exactly 10 times less than the oem , dont know who makes the oem but the arps should be the best we are going to get
RedHeeler79
Posted: 10 Jan 2026 at 8:47am |
Oem p/n’s are 74515070 -bolt
74516821 - nut. They appear to be pretty pricey. At one time I had an NOS connecting rod, and it did not have the castle nut with cotter key on the rod bolts, like the originals. It had a crown lock style locking nut, and there was maybe one thread protruding, if that. I’d assume that if the bolts/nuts were ordered from AGCO, they’d be the newer design. Hopefully the ARP’s will work. Post part numbers if you would, once you get them verified. Thanks |
JosephD17III
Posted: 10 Jan 2026 at 9:57am |
Definitely keep us posted id like to replace mine if my motor is worth a rebuild
HudCo
Posted: 18 hours 42 minutes ago at 10:53am |
have 24 rod bolts and nuts ordered and on their way form arp the sample one they sent was perfect,, dont have the part number handy but i will get it posted
RedHeeler79
Posted: 18 hours 18 minutes ago at 11:17am |
Great, thanks for the update. I’m going to order a set once we know the part number.
