262 diesel rod bolts
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 262 diesel rod bolts
    Posted: 04 Jan 2026 at 2:06pm
need a part number or source for rod bols and nuts the oem part numbers seam to not go any where on the innernet  does arp have somthing i am going to order new head studs from arp  my origanal block had studs my doner block had bolts.      but for now we need to find rod bolts
JosephD17III View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JosephD17III Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 8:30pm
I don't know where to find one, if you have a local tractor graveyard you could try there. Otherwise maybe the more experienced members would know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 10:13pm
we found enought new ones this morning oems from a few differant dealers but i am going to try and get arps .     absolutly no used rod bolts        especaliy on these old engines that have probly had a half of dozen in frames
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 9:00pm
Keep us posted on this. If ARP has a replacement, would you let us know? Or post the p/n of the original bolts/nuts, if still available? I’m strongly considering replacing mine before final assembly. Don’t want to take chances after all the headaches it has been getting this far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2026 at 10:31pm
arp is sending me one bolt to see it it will work , it sounds like the nut will end up exactly flush with the end of the bolt.    think we will machine the rods and cap just enought to get a full thread past the nut  also the grip lenght is about 1/8 longer that shouldent hurt. because thier is only an 1/8 grip in the cap .     if it will be ok they have plenty and they cost exactly 10 times less than the oem  , dont know who makes the oem but the arps should be the best we are going to get
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 12 minutes ago at 8:47am
Oem p/n’s are 74515070 -bolt
74516821 - nut. They appear to be pretty pricey. At one time I had an NOS connecting rod, and it did not have the castle nut with cotter key on the rod bolts, like the originals. It had a crown lock style locking nut, and there was maybe one thread protruding, if that. I’d assume that if the bolts/nuts were ordered from AGCO, they’d be the newer design. Hopefully the ARP’s will work. Post part numbers if you would, once you get them verified. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JosephD17III Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 2 minutes ago at 9:57am
Definitely keep us posted id like to replace mine if my motor is worth a rebuild
