262 d energy cell cap thread size |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Topic: 262 d energy cell cap thread sizePosted: 24 Oct 2025 at 10:54pm |
what are the thread size and pitch for the energy cell caps 1/4 by coarse or fine ?
HudCo
Posted: 25 Oct 2025 at 7:06pm |
their can only be about three or four threads cant tell what to tap with having sixty five yaers of paint and rust ant dirt pluging the holes
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5175 |
Posted: 25 Oct 2025 at 8:23pm |
If it's a straight 1/4" thread it's either 20 TPI for coarse or 28 TPI for fine. If it's 1/4 pipe thread it's tapered and, if I remember right, 14 or 16 TPI(?)
RedHeeler79
Joined: 09 Sep 2023 Location: NE Kansas Points: 246 |
Posted: 25 Oct 2025 at 8:47pm |
Would like to answer your question with certainty, but I can’t tell for certain. I have 2 sets of them, one set has no holes, the other set is so rusty, crusty and eroded that its hard to tell. It looks more like 1/4-20, but seems like they would have made it fine thread instead since the holes are so shallow. I did get a 1/4-20 bolt to kinda sorta start in the best one of the threaded set of caps… I ‘think’ they’re coarse thread. Definitely not 1/4 pipe, the holes are too small even for 1/8 pipe…
Edited by RedHeeler79 - 25 Oct 2025 at 8:48pm |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3190 |
Posted: 26 Oct 2025 at 7:17am |
Go to a hardware store and try different nuts on the bolt until you find one that works.
HudCo
Posted: 26 Oct 2025 at 11:55am |
they are 1/4x20, i would have thouhgt fine thread to get more threads. i took a 1/4 x20 tap and ground it off flat when its bottomed you will only get three threads. i put a grade 8 bolt on the end of a slide hammer four came out decent and two had to have a lot off beating around the edges and heat i, will probley have to replace those caps because it made little bulges bad enought they probley wont lap back in
