2600 Disc Power Requirement
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 2600 Disc Power Requirement
    Posted: 26 Dec 2015 at 12:01am
I saw an ad recently for a 22' 2600 disc nearby. It is a bit out of my price range, but it got me wondering if I could even pull it with the 8030 PS FWA. Currently, to give you an idea of my soil, I pull a 7 shank 1500 min till 5th to sixth on the flat in good ground, but if I hit a clay and or a hill I am usually down to 4th.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 3:49am
Around here in our dirt, that would be pushing the limit of it.i have a friend that pulls a 22ft with a 150 hp tractor and that's all it needs.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 7:44am
It isn't necessarily the width, but the weight per blade, the number of blades, the angle of the blade gangs and how deep you disc. A model 2500 double-fold that is 25 ft width and 9 inch spacing works well behind an 8050 or 7060 2WD in gently rolling ground. It is also set at the minimum angle on the gangs. A model 2600 is heavier than a 2500. If it is a center-fold frame, it will pull easier than a double-fold frame. It should also be an 11 inch blade spacing for 24 inch diameter blades.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 3:42pm
I pull a 22 foot center fold 2600 with 9 inch spacing with my 4w220 or 8070 MFD and with it set midway on the angle it will may them work in heavy soil.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 4:22pm
A 23 ft 9inch spacing 24 inch blades, will pull as hard as a 30ft 2500 7inch spacing 20inch blades.
     IG
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 9:16pm
Father in law bought a new 1, pulled it with a 9000 ford that was turned up to 180+ HP. Worked good with new rear tires and new tires on the duals. Tractor engine only lasted 3 years at this HP output.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 9:37pm
If I pulled my 22 foot Sunflower with my 8030 the Allis disc should be a cake walk. The Sunflower was a handful but I managed.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 11:37pm
my center fold is a real aggressive disk. does a great job, it goes in deeper than the IH and jd we had!
