2600 DISC PARTS NEEDED
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: 2600 DISC PARTS NEEDED
    Posted: 04 Apr 2018 at 6:00am
HELLO
LOOKING FOR RH & LH  SCRAPERS AND CLIPS FOR A 2600 DISC (THESE ARE THE RIDGED SCRAPERS NOT THE SPRING LOADED SCRAPERS). THE PART #'S I CAME UP WITH ARE 70585331 RH 70585332 LH 70585333 CLIP ALSO LOOKING FOR BRACKET BRG 70583716 (THIS IS A GANG HANGER)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 4:35pm
STILL LOOKING ANY HELP WOULD DEEPLY APPRECIATED
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 8:47pm
Hangers and scrapers are still gettable from Agco but hold on to your shorts. I have to buy a hanger last year and it was $360 if im not mistaken. There are two styles of ridged scrapers, on earlier models the scraper is one piece and has a clip that goes on top with the bolt inbetween two pieces of flat stock. The second bolts on to a square tubing and has a reversible scraper. They were $54 from agco.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:30pm
I have a complete set off a 26' model 2600  do you have a picture of which ones you are looking for?  That way I can see if mine are the ones you are looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 7:50pm
STILL LOOKING FOR SCRAPERS AND BEARING / GANG HANGER, WOULD ANYONE KNOW IF THERES ANY OTHER DISC THAT USES THIS SCRAPER?
WINTEREQUIPMENT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WINTEREQUIPMENT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 1:01pm
Good afternoon, we have many used AC 2600 disc parts available including bearing hangers, spacers, bearings and flanges, scrapers, wheel hubs and more.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 4:57am
There are some current listings on ebay for 2600 parts, take a look.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 8:50am
Pay no attention to WINTEREQUIPMENT's post. Likely a scam
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 1:23pm
Desperado8950 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Desperado8950 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 8:55am
Would you happen to have a turn buckle
Edited by Desperado8950 - 18 Nov 2023 at 8:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 7:32am
SORRY DO NOT
