25-40 tractor
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: 25-40 tractor
    Posted: 31 Aug 2012 at 2:02pm
Hi. Guy's I just picked up a 25-40 tractor. Ser.#24886 Engine ser.#45828 From what i found it is a 1931. It is on rubber tires now the flat spoke are weled on to rims. It is stuck for now working on getting loose. One rim is rusted half away it had fluid in tires. Did all 25-40's have a drop front axle. What is the best way to know if it is a 25-40 or a20-35 my water pump is on the block in the middle of the engine. Were is a good place for parts, gauge. What are the correct decal and placement I have seen some on rear fenders and some with out. Dose someone have a photo of one that is correct
Thank You
Rod in MN
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 4:02pm
From the serial # it should be a 25-40. Do you have any pictures you can post? Did you have to go far to get it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 5:53pm
I have quite a few used parts for the 25-40's YOu can send me a PM or email me at mbscott881@hitmail.com     Thanks Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 10:46pm
HI, MNLonnie  It was about 10 miles from my Dad's place in West central MN. About 110 miles from my place By Rice MN. just got to my place on Wednesday night I have 3 other tractors to get done first 2 are primed So trying to get things lined up and found . So i will be ready when it is it time for restroration
Thank You Guy's
Rod in MN
This page was generated in 0.467 seconds.
