24v starter requirements
smokyblaq View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokyblaq Quote  Post ReplyReply Direct Link To This Post Topic: 24v starter requirements
    Posted: 02 Dec 2023 at 8:51am
 hd 6 crawler
I read in another post that the 24v starter requires two 24v batteries is that a type"o" or is there two 24v batteries hooked in parallel
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 9:16am
You will need two 12VDC starting batteries in series wiring configuration for 24VDC power.
That's All Folks!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 11:56am
The starter doesn't care how many batteries or what the Number on them says as long as at the end of the cable hooked to starter there is 24V of voltage .
 Now the generator might insist the polarity of the batteries is in one direction , the starter doesn't care which way .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 1:15pm
The 7G I had was 24V start charge, had two group 31 batteries, worked a charm, did convert to N Ground and hung a 24V Alternator, made life simpler.
