24 valve cummins
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Topic: 24 valve cummins
    Posted: 07 Mar 2010 at 5:01pm
Need to know what way the valve bridges (under the rocker arms) go on one side is oval other is round
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 5:20pm
Shouldn't matter. If one side is oval and the other is round, that means its a floating valve bridge. Once the engine is started it will cnter itself. A 3406E CAT is set up the same way
1968 D15D,1962 D19D
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 7:05pm
One side is opened up a bit (slotted) to prevent any chance of binding due to spacing tolerances and guide wear.
This page was generated in 0.123 seconds.
