2300 disc spool needed
Jmcneese00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jmcneese00 Quote  Post ReplyReply Direct Link To This Post Topic: 2300 disc spool needed
    Posted: 05 Sep 2021 at 2:34pm
I recently purchased an 8 foot 2300 series disc. It had a bad inner bearing on one of the rear gangs. I think I have found the correct numbers for the bearing and the flange but the short spool beside the bearing has been worn down and needs to be replaced. I believe the size I need is 2 7/8” and the shaft is 1 1/4” hex. Does anybody know where I can find one of these spools to order online or the correct part number?
Thanks!
Jake
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 7:08pm
call agco.
Bearing 70586143
Flange  70586144 with fitting
Flange. 70586145 plain
Spool.  70571749 long 3-7/8”
Spool.  70571750 short 2-7/8”.
If you don’t have an agco dealer I could help you. But shipping from ny won’t be cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jmcneese00 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 1:20pm
Thank you! I have a Massey Ferguson dealer close that might be able to help me get them through AGCO. I might let you know if I can’t get that to work out!
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 3:31pm
Agco has all the parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 4:06pm
yes I just recently bought some through agco
This page was generated in 0.152 seconds.
