2300 Disc Questions
housemover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote housemover Quote  Post ReplyReply Direct Link To This Post Topic: 2300 Disc Questions
    Posted: 08 Nov 2020 at 12:04am
    This week I brought home my 3rd 2000 series disc.   Number 1 purchased 1/2 & 1/2 with my father 20+ years ago was a 2200 with manual wings.   Number 2 was a 2300 with manual wings.   What an improvement in weight , bearings, etc.!   Number 3 is a 2300 with the black gangs  &  hyd. wings.   Again WOW what an improvement .     To my amazement though I don't  see any way built into the disc to manually retain the ext. gangs in the upright position during long term storage.   I own a copy of A/C Manual #573261 for the operation of the 2300 Series Disc but there is no mention of this in the options section.   Has any one out there in "Unofficial Allis Land" have any experience with this.  I am sure that I'm overlooking something on the parts that are put on with the hyd. option.  Also I'm missing 4 of the bent flat iron holders that hold the scrapers to the extension gangs.  Would be in the market to buy if anyone has them!    Thanks,   Housemover
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 4:00am
Maybe the wings are like the 1200 series fieldcultivator where you have to raise the wings hydraulically and then push by hand the wings over center so they rest in a position where they can't lower. Then when you want them down you hydraulically lift the wings so they are to that over center point and then you push them over center by hand and then lower them hydraulically.
Wink
I am a Russian Bot
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 6:05am
Any way you could post a photo of what you have in the hinge area? Mine has locking pins.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 8:06pm
The pin in the top hole needs to be put into the empty bottom hole for transport.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 8:11pm
Another pic:
Do you see the pins with the quick pins?   And the lower hole?
Edited by Ron(AB) - 08 Nov 2020 at 8:19pm
