230 Gas VS Diesel block
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: 230 Gas VS Diesel block
    Posted: 06 Feb 2012 at 9:06pm
ok, im curious.  is the 230 gas block different from a 230 diesel block?   i have seen wd45 diesels advertised with craked blocks.  is it possible to use the gas block?  probably not or they would be getting fixed  i have a 230 gas from A2 combine but no buda block to compare
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:23pm
I know that the 262 gas and diesel blocks are the same. Neighbour just rebuilt his D-19 D and the block was bad so they found and used a gas block. I don't know about the 230 but the same should be true. If you use the gas block, it will have only one oil filter.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:29pm
230 out of an A2 is a newer version of the 230, same block as 262 gas and diesel, has the o-ring grooves in the block instead of on the sleeve like the WD45D 230. You would have to use the sleeves that are in the gas block, there are other things that you would have to do also, notch frame rail for the full flow oil filter or remote mount it, there is no pivot shaft on the newer block for the throttle linkage bellcrank or what ever you want to call it,water pump opening in gas block will need to be blocked off, there is probably other things I am not thinking of right now, but it can be done, just won't look original.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:34pm
There are some old 230 gas blocks that has the castings on the block for the two oil filters.
  If any one needs one I have one for sale.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:44pm
Originally posted by Kevin in WA Kevin in WA wrote:
........, just won't look original.
course not.. its a gas lol
i did have a wild hair about putting it in a tractor but im thinking about unloading it as i have too many projects.  and without a dead 45 diesel to start with... its alot more work
This page was generated in 0.115 seconds.
