230 and 262 cylinder head
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 230 and 262 cylinder head
    Posted: 05 May 2025 at 9:44pm
is the wd45 diesel cylinder head , and the d17 262 in the series 1 cylinder head the  same
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 1:34am
They look identical but question is are they?
28 years ago I had a 17 and 45 head set side by side and they looked like twins, but I did not measure anything at the time, nor take any pics and now that memory is not so great anymore.
Would have to look up in the wd45 Diesel and the D17 Diesel manuals to see if valves were different and any other things, injector tips were different numbers if I recall correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 10:07am
I would bet they are inter changeable not identical. Likely different casting #.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 12:04pm
When i was looking for a head for my ‘57 D17 diesel, i was told they were not the same. Casting # on my engine is 4507716, if that helps at all. I don’t know what the difference would be, as they looked strikingly similar to me, in pictures. The injectors not being the same between the 230 and 262 could very well be the difference in head castings. Maybe someone else can answer that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 5:52pm
According to AGCO parts books, the cylinder head itself is a different p/n. But, the valves and guides and head gasket and energy cells are the same between them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 7:44pm
thier was a wd45diesel on aution about fiftee miles from me today   the tractor is beat to death been drivin past it for years  thats why i was wondering went for 1200.00 al four tires  have held air
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 8:16pm
If its like the gas  motors the water pump holes are different,later models were larger.
This page was generated in 0.154 seconds.
