23/32??? Does this mean more tools?!
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: 23/32??? Does this mean more tools?!
    Posted: 25 Jan 2012 at 2:45pm
Started the bulk tear down of the WC.
Though it was new to me, dad was well aware.  We had to raid the antique wrench box of my grandfathers for the 32nds size wrenches.  But nuthin to fit the long arm for the extra leverage.  It was lucky to still have all the original tools (maybe not as we don't through out much)
Not sure if my wife will be happy see me come home with more tools...but maybe not as hiding a tractor as some seem to be trying to do.
metric works in a pinch but some of them can get jammed in the socket pretty tight.
Still like the thought of adding to the tool box though I never need much reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 10:37pm
Here's Dad assessing the project.  Canadian weather has been hard on the sheet metal and tires but the rest is in good shape,  The inch of oil and grease on the engine has preserved t well.
Edited by Redwood - 25 Jan 2012 at 10:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 8:06am
That's why I have an assortment of Crescent wrenches. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 10:19am
I agree,  I have a three different sizes of those.  My tool of choice used to be vise grips.  though both can spread.  Those really stuck heads like a six point socket....Or the torch.  If it ain't a stud I'm not too concerned. It is nice that my grand father took good care of his stuff while in use. If it hadn't been for the lack of barn space this would have never been left outside. any bolts that have been off for maintaince might have well been off last fall.  It's the ones that havn't been off since it left the factor that are the problem.
But I must say to me it feels good to use the same tools that where used on the tractor when it was in use.
Edited by Redwood - 26 Jan 2012 at 10:30am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 11:05am
Although I have one from a very old Sears socket set never have I ever used a 23/32 socket, except to knock it on a rusted 3/4 nut.
Now the 19/32 in the same set is a differant story. I have used it. Once,,, in close to 50 years of spinning wenches again aside of knocking it on rusted 5/8 nuts.
Edited by Butch(OH) - 26 Jan 2012 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 11:20am
Joking aside,I won't be rushing out to get the specific 32nd's sockets.  Picking the closest thin or the adjustable to get them off. and standard sizes will be going back on unless it is threaded into cast, like the bolts holding on tht gas tank/light mount on.  But those will never come off in my life time again.  They are only coming off for painting anyways.  And I do have my grandfathers wrenchs once the bolts have broken loose.
Ya, I don't want to grab a new tool I'll use once.
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 12:31pm
Redwood, try an 18 mm metric socket. If the socket has 10/1000's clearance it should go on. 23/32 works out to about 18.25 mm if my math is right
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 1:00pm
if memory serves, there's something on the right front side of a WC or WD that uses a 19/32 socket.  Might've had something to do with the steering shaft support.
This page was generated in 0.085 seconds.
