23.1-34 tire |
MattLF9 ![]() Bronze Level ![]() Joined: 27 Nov 2009 Location: Minnesota Points: 187 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Nov 2019 at 7:04am |
I blew a 23.1-34 tire yesterday while combining beans.
I called around to some salvage yards and tire shops, nobody has that size. Anyone in Minnesota have a good used one? |
A little CQB never hurt anybody.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22087 |
Ideally, you want to find the same size and BRAND as your good tire. If you don't, your header won't be square to the ground and cutting beans cleanly may not happen.
I bought it with mismatched tires and it's been this way for 8 years.
It's always leaned to the left, I call it the Leaner combine. The good tire is a Co-op, and it's probably the last one in existence, no chance of finding a match. |
Chad (MN) ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: sc minnesota Points: 288 |
You try Midway Farm Equipment, Mt. Lake? Maybe steve fischer on this site?
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Yeah, I called Midway immediately and they don't have one.
WLHD21 ![]() Bronze Level ![]() Joined: 06 Feb 2019 Location: Iowa Points: 155 |
I have a set of Firestone rice tires from Gleaner G 563-380-4509
I don't think what you have will fit my N5.
Tim NH ![]() Orange Level Access ![]() Joined: 16 Oct 2012 Location: Lancaster NH Points: 1125 |
I'm not sure if this company sells used. But worth checking out. Tim
Hey thanks for the link Tim!
They don't have them either. I'm even looking for the metric equivalent 620/75R34 also. |
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
NTS tire supply has some but their not cheap...
Edited by lowell66dart - 01 Nov 2019 at 3:29pm |
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
EBAY has what look to be blems, new for $899 each.
Yeah I saw those too, but they removed the name and serial number.
Looks too shady. |
DCAC ![]() Orange Level ![]() Joined: 20 Oct 2018 Location: east central SD Points: 512 |
Twin Valley Tire in Milbank, SD, 605-432-4505. Or perhaps Meyer Salvage in Aberdeen, SD, 605-225-0185.
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8658 |
I thought Firestone made co-op tires????? Give Worthington ag a call. 888 845 8456 they have 9 other yards. |
There's nothing out there for used tires.
I went ahead and bought 2 shady deal tires on ebay. |
I've got to admit, I've never seen 23.1 x 34's on any N-5 combine. They were always on L-series.
This is the only N series I have seen them used on.
I think 30.5-32 is the normal tire for these. |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8662 |
No complete set tire/wheel 30.5's at salvage worth the money? Probably only set you will need to buy
It would have been my next option, believe it or not, it would have been more money.
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
We have a couple decent spares down here in NW KS, but the freight would have been terrible. Mike's Equipment at Buhler KS would have surely had some too.
Sounds like the N5 has the standard finals with the small bolt pattern and someone swapped tires and wheels off a L series, as N5s would have had 20.8x38 or 18.4x38 if it was smaller than 24.5 or 30.5x32. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
It has the S25 final drives.
