226 engine build |
firephight
Topic: 226 engine buildPosted: 16 Jul 2013 at 9:05am |
I am wanting to build a engine to swap in my stock 45.I am going to use a gleaner block and found a 175 cam with 45 crank.just looking for some setups that others are using. Drop me a p.m
WCCLASON
Joined: 01 Jan 2010 Location: Viroqua Wi Points: 106 |
Posted: 16 Jul 2013 at 9:17am |
to keep it simple....Use WC flat top with the 45 crank. gives you more compression....and port the head....that's what I have and it runs really well. I have new stock size valves with a three angle valve job with back cut valves as well. I also have one with a actual 175 cam and it is a tough tractor. I on that tractor I am also just running a Gleaner E carb as well....Nothing to special but when done right makes good power. Just my 2 cents...
cotncrzy
Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
Posted: 17 Jul 2013 at 7:32am |
Yep, WC is right simple build for lots of power increase. Find a little different piston, or modify yours to increase compression and it make alot of difference.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 17 Jul 2013 at 10:35am |
i wonder why when the hp went up allis engineers increased Main bearing size and used a stiffer block with better oiling system. lol
Edited by mlpankey - 17 Jul 2013 at 11:00am |
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 17 Jul 2013 at 11:30am |
Not sure you can use a gleaner block and a 45 crank...
