226 combine engine into a wd45
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: 226 combine engine into a wd45
    Posted: 13 Jan 2012 at 8:07pm
i can get a complete 226 out of a combine but i was wondering what all i need and or change to get it to run.. i know ill need the gov off the tractor plus the bell housing.. anything esle needed or missed
if farming was easy everybody would be doing it
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 8:12pm
  change gov. setup--wAter pump--carb linkage-throttle shaft or put the one from tractor---done many    1-574-342-4545
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 10:19pm
The whole front plate is what I understand needs changed over. The bellhousing isn't different. 201's and 226's all have the same bolt pattern. Pretty straight forward swap.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 11:12pm
You will have to grind some off the frame rail for the governor casting on the block. Be the right side of the block, it'll hit the frame, grind like a 1/8-1/4 off and as wide as the casting.
Carl
This page was generated in 0.104 seconds.
