220
dirtschlinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtschlinger Quote  Post ReplyReply Direct Link To This Post Topic: 220
    Posted: 19 Jun 2019 at 8:15am
I recently replaced the cobbled up fuel line on my 220.  I want to add the tractor did run out of fuel.  I put an electric fuel pump on it and new fuel filters.  I bled the fuel filters and they are full of fuel.  I was going to crack the injector lines but the nut doesn't want to turn on the steel line so I thought I would just try to roll it over and see if I get smoke.  I rolled it over and got smoke and it eventually started.  It ran rough for a bit but then smoothed out.  It runs good at an idle up to about 1/4 to 1/2 throttle then starts to run rough and alot of brown to dark brown smoke out the stack.  Pull it back down under half throttle and it clears up and runs smooth.  Is this the result of not bleeding the injectors?  Is there a good way to get the injector nuts to break loose without damaging or twisting the lines?  It has the inline Minimec pump with AC injectors.  Thanks.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 8:32am
sounds like a fuel restriction to me
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 8:42am
Why an electric pump on a system that is easily fed by gravity ???? Just something else to go WRONG.
