220?
allis/cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Topic: 220?
    Posted: 13 May 2016 at 10:00pm
Will 38 inch cast centers from a 7000 series work on a 220 with 30.5x24
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 10:29pm
To the best of my knowledge they should work with your wedges.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 10:41pm
Ok perfect :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 11:40pm
Wedges are axle specific.Wheels are not...sorta.7030 up should be fine I think a 7000 may have different center? Look in AGCOpartsbooks.com
Arcs and Sparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcs and Sparks Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 8:54pm
When I purchased my 220 the rear castings were both cracked?   It had 38" centers.  I searched forever to find vintage exact replacements.  I did in fact find several sets but always one of the pair would have hairline cracks in the same spot as my 220 had.  All were casting # 265221-03.  In the end I went with a set of 38" castings off of an 8030 They had already been removed from the tractor and were stored in a rack at the local salvage yard.   They had "removed from an 8030" painted on them using a paint pen. .   These were casting # 271989-02.   As mentioned earlier your wedges make up the variation for your 3 5/8" axles.  I purchased the Agco pilot bolts and a 7/8" X 12 TPI tap to chase the holes in my wedges.  That is an odd tap but they are still available.  An old mechanic later told me that they just re-tapped the wedge holes 1"-8 UNC and used grade 8 bolts as the jack bolts to drive the wedges off.  I have since talked with a person who switched his out centers with centers off of a 7060.  These were a 70254094 casting.  I think you have many donors that you can use the castings off of.   We had both wheels switched out on my 220 in less than 1 1/2 hours.  Good luck.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 10:10pm
Any 210/220 7010 thru7080 and 8010 thru 8070 will interchange. Keep the wedge with the tractor it was on always, and use any of those centers.
