220 wheel problem
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Topic: 220 wheel problem
    Posted: 28 Oct 2016 at 2:29pm
Trying to put new tires and rims on a 220 with 18.4x38s. I either have the wrong rims or am missing something cause as it sits these wheel clamps ain't gonna tighten all the way without breaking something. Anyone see my mistake or had a similar struggle?
Edited by skateboarder68 - 28 Oct 2016 at 2:31pm
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 3:32pm
There is a sequence to tighten those clamps, should be in owners manual, maybe that will help.
Do you have the 3 missing clamps?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 4:20pm
those rims must be for an IH? I've got rims off a JD on my 210, and they fit perfect, and all 7 lugs match their clamps. Not all double bevel rims are the same.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 8:35pm
I put a set of 13.6x38 on 190xt for spraying and they were the same way.    MACK
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 8:40pm
I just swapped rims and tires off a 210 onto a 220 this spring, and if I remember correctly that is about how they started out.  You will never get them completely tight up against the cast, there should be a small gap, otherwise they will never really be tight on the rim, but on the cast instead.
I just noticed that two of the clamps don't line up with the torque bumps, that will be a problem, because of uneven clamping pressure.  What kind of pulling are you doing with this tractor?  Our center cast, has fewer clamps if I remember correctly.
Edited by Orange Blood - 28 Oct 2016 at 8:43pm
Still in use:
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 4:42am
I put them on just like a set of daytons on a truck. Jack the tire completely off the ground so it spins. Then place a block of wood on the ground after you've started all the clamps. Spin the tire and tighten where ever the rim/tire wobble towards the block. There is a torque spec for those but i just use my judgement with an impact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 8:15am
I think I have the wrong rims, hopefully I can exchange them. Thanks guys
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 9:09am
i am going to say that they need to be lossened backup and center the wheel a little better make ,    sure the wedge area is clean  so that the wedges move evenly,  little drop of grease wont hurt somtimes
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 7:06pm
As has been said, you won't get the clamps tight against the cast, that would defeat the purpose and not give you any adjustment if they loosen over time. Looks right otherwise just get it centered and tighten in sequence.
