220 tractor s/n versus 426 engine s/n's |
Topic: 220 tractor s/n versus 426 engine s/n'sPosted: 02 Apr 2023 at 6:38pm |
220 tractor chassis s/n is 1012. The engine is 3D-09771. So, any D-21 engines are at least 12 engines before this 9771 s/n range. I actually saw D-21 s/n 1003 or 1004 many years ago (it got turned into a pulling tractor) and the engine was like 3D-1030 or so.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 03 Apr 2023 at 5:47am |
Where did the 210 fit in? According to Tractordata.com, both the 210 and 220 were manufactured from 1970-1973m but, for some reason, I thought the 210 was out before the 220.
Posted: 03 Apr 2023 at 6:25am |
Nope. The 220 was out 2 years?? before the stripped down/turned down model (210) was released.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5114 |
Posted: 03 Apr 2023 at 8:03am |
I have the original block from my 71 210, tractor sn 1893 engine sn 3D15855. 210 came out in 70.
Posted: 03 Apr 2023 at 1:44pm |
A customers 1969 220- s/n 1085 has the engine at 3D-09936. My brothers early 1972 220 has chassis s/n 2272 and engine 3D-16989. It also is new enough to have the "fast low range" transmission option like the FWA tractors all had.
Edited by DrAllis - 04 Apr 2023 at 6:57am |
injpumpEd
Posted: 04 Apr 2023 at 2:58pm |
My puller 210 has fast low range also, but the "new" one I bought is a 72 s/n 2346, and does not have fast low, which stinks, because when I swap my trans to the "new" one, I'll have to swap the main shaft from one to the other lol! Never simple! 23T output vs 24T output.
Posted: 04 Apr 2023 at 3:28pm |
In our country, fast 4th is 5.8 MPH and regular 5th is 6.3 MPH. Two perfect tillage speeds !!! And I think fast 3rd is 4.5 or 4.6 which is the same as regular 4th.
Posted: 17 May 2023 at 9:21pm |
A new entry from Phil Brown....220-2306 chassis and 3D-12857 engine.
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1759 |
Posted: 01 Nov 2023 at 2:49pm |
That last one from Phil Brown seems out of numerical order engine vs chassis. 220 at auction by me #2738 has engine #3D-17282, 2254.3 hrs
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Posted: 01 Nov 2023 at 6:31pm |
Yes, I was questioning if his had had an engine put in it at one time, new or used. His chassis was new enough to have had the newer crankshaft driven oil pump, so who knows what happened. There were some of those early camshaft driven oil pump drive gears that failed and it usually happened in the field at full throttle/full load and nothing was left in the crankshaft/line bore/ connecting rod area and the turbo. I imagine, if warranty or good-will gesture from A-C, they swapped a complete engine. A-C didn't really offer "short-blocks" back in that time frame, or not at least thru the Ag dealers network.
Edited by DrAllis - 01 Nov 2023 at 6:34pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Posted: 12 Jan 2025 at 8:57pm |
My 220 is a 70. ser # not handy but tag on engine has no serial #...just 3500. Has crank drive pump and slow low. Would guess it had and engine replaced.
Michael V (NM)
Posted: 27 Jun 2025 at 9:40am |
I have 220 #1025, engine # is 3D-09764,, so,, I'm guessing, the engines were not pulled off the line in exact order to be put in the tractor's,, OR,, it has been changed sometime back in it's earlier life..
Posted: 27 Jun 2025 at 9:49am |
I would say yours is very legit. My friend has 220-1085 chassis and 3D-9936 engine. Yours is 220-1025 chassis and 3D-9764. Chassis difference of 60 tractors and engine difference of 172 engines. They were using that engine is gen sets and construction equipment at the same time the 220's were being built. I'd say it's spot on. The 220 tractor I owned was 1012 chassis s/n and 3D-9771 engine. So, that kind of proves as the 220 chassis was going down the assembly line, there was a stack of engines (sent from the Harvey, Illinois plant probably 25 at a time?) and their eng s/ns didn't have to jive with the chassis s/n's. Just grab an engine and stick it in a chassis. My 220-1012 and your 220-1025 may have been built on the same day or surely consecutive days. The engines were only 7 numbers apart while the chassis were only 13 numbers apart. 220 engine s/n's continued from the D-21 days and all the other things that it was used in from 1963 until 1969 when the 220 came out.
Edited by DrAllis - 27 Jun 2025 at 10:33am |
Michael V (NM)
Posted: 29 Jun 2025 at 11:23am |
well, now that I'm very sure my 220 has the original engine, that sure does change my plans for sticking this genny engine I got for it......(yea, I know they hafta be stripped to pretty much bare block...)
I don't think I can get the SN tag off and re-installed without wrecking the tag...
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1074 |
Posted: 13 Jul 2025 at 11:26am |
We have 220-2637. No engine in the chassis but the one that came with is sn 3d-16447. No way to find out if it was the original but seems like it is very close from what I read
im4racin
Posted: 15 Jul 2025 at 11:47am |
We also have a 210 sn 1884. Has engine 15312
Posted: 15 Jul 2025 at 12:09pm |
210's came out 18 months ( ???) after the 220 did, so there will be more and more 3500 Mark I engines being split between 210-220 and gen sets and construction units.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
Posted: 23 Aug 2025 at 6:32am |
Yeah that makes sense. I remember coming across an early D-21 years back at a show, and the engine number didn’t seem to line up super tight with the chassis either, so your numbers fit with what I’ve seen too. A lot of those early ones ended up as pullers around here, so it’s always tough to know exactly what’s original anymore.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4550 |
Posted: 18 hours 3 minutes ago at 7:38pm |
426 engines were used in gensets, loaders, trucks, combines, crawlers (7G ,C series) and sold to other manufacturers so there is no way to correlate tractor and engines serial numbers. As the DR. said, Harvey sent a truck load of engines and they just grabbed one and stuck into a tractor. The same happened with the 220 fwd front axles from Rockwell. Just grab one and install it. My 220 fwd is the 20th built and has front axle #10 . The first one sold has axle #14.
