220 tie rods
d17series4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17series4 Quote  Post ReplyReply Direct Link To This Post Topic: 220 tie rods
    Posted: 29 Jun 2017 at 3:49am
Does anyone make any aftermarket tie rods for a 220. Thanks Chad.
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 5:03am
I cant answer the availability question, but if you find any they will probably come with inferior pressed steel clamps. Throw away the clamps and salvage the OEM clamps from your OEM tie rod assemblies. They will hold the telescoping joint much more securely than the replacement clamps.
This applies to any of the replacement assemblies that I have seen on any of the Hundred series tractors.
