220 Questions
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 220 Questions
    Posted: 26 Feb 2026 at 7:34pm
S.N. 1988, what year would that be? And lastly, the nose cone on a 220, is that made out of tin like the 200 or is that a cast-iron nose cone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 7:38pm
The nose is a big ole piece of cast,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 9:03pm
...and the axle pivot block is one HUGE chunk of cast...the 210 used a hollowed out block and a tin surround.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 7:50am
I've seen some 72 220's and they had the hollow front support like the 210.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 9:00am
I don't know at what S/N that took place, but yes, the later 220's had the hollow front support like a 210.  Cost savings measure. You buy MORE front end weights for an 8 bottom plow.   S/n 1988 is an early 1970 model year.
Edited by DrAllis - 27 Feb 2026 at 11:57am
CS_IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CS_IN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 11:27am
I will have to look at mine tonight.  It is 26 from the end i believe.  Its still new to me and I didn't know about this difference. It had the suitcase weight bracket on it when i got it instead of the block style weights. It does have crank driven oil pump and larger oil pan.
Edited by CS_IN - 27 Feb 2026 at 11:28am
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2026 at 10:16am
I purchased a 220 in fall of 23 and have redoing it and getting close to having it finished and my daughter wanted it to pull with so it's her's now.
I was told it come from Iowa and had a cab on it and I don't remember
the serial number off hand but supposedly it's 200th tractor from the
end of production of the 220 and it also has a 210 bolster on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2026 at 10:19am
C.S.,
Did you change the front weight bracket on your 220
to slabs.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2026 at 10:37am
Originally posted by Kevin210 Kevin210 wrote:
C.S.,
to slabs.
  Hey!!!   I want that weight bracket!!!WinkWinkWinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CS_IN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 7:00am
Here is a picture of the underneath of my front axle bolster.  I'm not sure which one it is but seems heavy.  Below is a picture of the weight bracket.  It is planned to remain as I don't have the block weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 7:53am
If it looks like you could put a socket on the front crank pulley easily too turn the engine over, it's the hollow one. Still very heavy, at least 600#, but the early one is solid all the way to the crank pulley, it would be challenging to get that socket and rachet on the crank bolt. The hollow one has enough room to remove the pulley actually. I bet the solid one is over 900#. I don't think the early one has those 2 big holes either. I always assumed the hollow one was designed to help "cheapen" the price for the 210, and once they came out, it just made sense to just use the same one on the 220, and sell a rack of suitcase weights to the buyer. I don't think there's an official serial number break, but it would be interesting to know about when the 220 got the hollow one. I'd guess sometime in 71, guessing it would have taken a while to use up all the solid ones they had made already.
Looked on agco parts books online, the 210 & 220 both call for 70256109. Shows serial # effective after 2036 for 210, and that is for the larger 5/8" bolts that hold the radiator surround. My older paper parts book copy shows for a 210, support #255790 and also shows 1/2" bolts for radiator surround. Oddly it shows no different part number under 220, but the picture clearly shows the solid casting and the 210 picture show the hollow one lol!
Edited by injpumpEd - 02 Mar 2026 at 9:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 8:04am
Anyone have an original parts book. See what part number is. If it gives two numbers or if the original number is different then in agco parts book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 8:27pm
C S,
I sent you a private message.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 3:28pm
C_S
Just wanted to check and see if you
got my message i sent about your 220.
