220 Questions
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 220 Questions
    Posted: 26 Feb 2026 at 7:34pm
S.N. 1988, what year would that be? And lastly, the nose cone on a 220, is that made out of tin like the 200 or is that a cast-iron nose cone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 7:38pm
The nose is a big ole piece of cast,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 9:03pm
...and the axle pivot block is one HUGE chunk of cast...the 210 used a hollowed out block and a tin surround.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 7:50am
I've seen some 72 220's and they had the hollow front support like the 210.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 9:00am
I don't know at what S/N that took place, but yes, the later 220's had the hollow front support like a 210.  Cost savings measure. You buy MORE front end weights for an 8 bottom plow.   S/n 1988 is an early 1970 model year.
Edited by DrAllis - 27 Feb 2026 at 11:57am
CS_IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CS_IN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 11:27am
I will have to look at mine tonight.  It is 26 from the end i believe.  Its still new to me and I didn't know about this difference. It had the suitcase weight bracket on it when i got it instead of the block style weights. It does have crank driven oil pump and larger oil pan.
Edited by CS_IN - 27 Feb 2026 at 11:28am
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 2 minutes ago at 10:16am
I purchased a 220 in fall of 23 and have redoing it and getting close to having it finished and my daughter wanted it to pull with so it's her's now.
I was told it come from Iowa and had a cab on it and I don't remember
the serial number off hand but supposedly it's 200th tractor from the
end of production of the 220 and it also has a 210 bolster on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 59 minutes ago at 10:19am
C.S.,
Did you change the front weight bracket on your 220
to slabs.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 41 minutes ago at 10:37am
Originally posted by Kevin210 Kevin210 wrote:
C.S.,
to slabs.
  Hey!!!   I want that weight bracket!!!WinkWinkWinkWink
This page was generated in 0.285 seconds.
