220 Questions
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 220 Questions
    Posted: 26 Feb 2026 at 7:34pm
S.N. 1988, what year would that be? And lastly, the nose cone on a 220, is that made out of tin like the 200 or is that a cast-iron nose cone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 7:38pm
The nose is a big ole piece of cast,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 9:03pm
...and the axle pivot block is one HUGE chunk of cast...the 210 used a hollowed out block and a tin surround.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:50am
I've seen some 72 220's and they had the hollow front support like the 210.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 57 minutes ago at 9:00am
I don't know at what S/N that took place, but yes, the later 220's had the hollow front support like a 210.  Cost savings measure. You buy MORE front end weights for an 8 bottom plow.   S/n 1988 is an early 1970 model year.
Edited by DrAllis - 20 hours 60 minutes ago at 11:57am
CS_IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CS_IN Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 30 minutes ago at 11:27am
I will have to look at mine tonight.  It is 26 from the end i believe.  Its still new to me and I didn't know about this difference. It had the suitcase weight bracket on it when i got it instead of the block style weights. It does have crank driven oil pump and larger oil pan.
Edited by CS_IN - 21 hours 29 minutes ago at 11:28am
This page was generated in 1.041 seconds.
