220 questions |
dirtschlinger ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2014 Location: Elmore, Oh Points: 51 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Aug 2018 at 9:17am |
Where can I get a key for a 220? I assume they are all the same and maybe a key from a different tractor may even work. It's my grandpas tractor and we can't find the key anywhere. There is a bracket that runs from one battery box to the other just behind the shifter. This is where my batteries are grounded. Is this correct? Is this a good enough ground? Thanks.
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2372 |
A lawn tractor key will fit unless the switch was changed with something different,INDAK is the company that made them. Should be able to find one pretty easy.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8644 |
that original key has been in tractors and lawn mowers forever,all alike and yes thats where the ground cables were attached.You can run them any place that works if you desire.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5029 |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5120 |
A small screwdriver works also
If that is the stile key you need, I'll send you one. MACK
Creek Jenkins ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Northern Minn Points: 812 |
217 more questions to go?
Have spacesuit, will travel
Thanks for the responses. I do need an INDAK key. I will find one. Thanks Mack. Careful what you wish for Creek
