220 only runs on either momentarily |
Kingz Livestock ![]() Bronze Level ![]() ![]() Joined: 16 Mar 2018 Location: Arcadia Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Mar 2018 at 2:17pm |
I have a 220 landhander that will only run on either for a few seconds, needing ideas to what's wrong. Thanks.
Jim Hancock ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Pump issues or plugged fuel line and/or tank
How blessed we are by HIS GRACE!
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
pump shut off pulled out?
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5100 |
I bet it's been sitting a while. The plungers in the pump are stuck, and it will not pump fuel until pump is properly repaired, and all of the fuel lines and tank need cleaned.
Thanks, Turns out pump is bad had a bunch of black chunks in it when I pulled the top off. Not being a mechanic I pulled the pump off without knowing I had to line up the timing marks. How bad is it to time the engine when I put the rebuilt one back in??
the shop who rebuilds it for you should be able to coach you on re-installation.
Ok thank you!
