220 front turf tires? |
Tim (Cent.WI)
Joined: 19 Sep 2009 Location: Stratford, WI Points: 214 |
Topic: 220 front turf tires?Posted: 21 Dec 2017 at 3:13pm |
Does anyone know if 220's came with front turf tires from the factory? If so what size were they? I would like to put a pair on my 220.
I like the looks of turf tires on the big horses like 210's, 220's and 7060 and 7080's |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2733 |
Posted: 21 Dec 2017 at 3:49pm |
I believe the only tractor that came from the factory with the diamond stud (or turf tire) was the 7080. At least from my recollection of what came into Dad's dealership in the '70's that was the case. Two Ten's, Two Twenty's, 7030, and 7050 all came out with a tri-rib tire from the factory. Again, just my experience but there may have been other dealers with something different.
JimWenigOH
Posted: 21 Dec 2017 at 4:07pm |
I was thinking about putting those on my 220 but was advised against it by the tire dealer. He said corn stalks are hard on them. I went with 4 rib instead.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 21 Dec 2017 at 8:07pm |
those diamond tread ones look kind of cool to me
LB0442
Posted: 21 Dec 2017 at 10:29pm |
Ya I like the looks of them. Got a set from the salvage yard for the 7080.
Tim (Cent.WI)
Posted: 22 Dec 2017 at 8:00am |
Just love that look! What size are those?
LB0442
Posted: 22 Dec 2017 at 9:20am |
They are 18.4 x 16.1.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 22 Dec 2017 at 9:45am |
18.4 x 16.1 I think they make a 220 look mean
HD6GTOM
Posted: 22 Dec 2017 at 10:32am |
In the years I was in the farm tire business I saw several 220's with the diamond tread. I do not know if they were stock. I do remember several new 7080's at R&R equipment in Indianola came with the diamond treads.
Tim (Cent.WI)
Posted: 22 Dec 2017 at 11:50am |
Calvin that is what I am talking about, that does look Mean!!
What do you have for front rims on it? |
aras
Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
Posted: 22 Dec 2017 at 1:58pm |
They are 16" wide -- the old designation for 16.1 was 16A for rim diameter. They have a huge offset and reinforcing rings from the factory. We have a couple sets on our tractors....
daveingreenbay
Joined: 09 Oct 2009 Location: Green Bay Points: 281 |
Posted: 22 Dec 2017 at 4:06pm |
I know where I can put my hands on a pair of Goodyear 18.4x16.1 Diamond tread tires, in case anyone is interested. 54155 zip code.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 23 Dec 2017 at 6:49am |
Have you priced a new 18.4-16.1 diamond tread (knobby) tire only lately? Make sure you're sitting down.
Posted: 23 Dec 2017 at 6:56am |
As far as I know, the first farm tractor to offer those front tires was the 7080 in very late 1974.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 23 Dec 2017 at 7:00am |
They look cool but wouldn’t they steer worse.
Calvin Schmidt
Posted: 23 Dec 2017 at 7:04am |
Stumbling through a local salvage yard looking for a matching 20.8 x 38 radial for the duals, I saw these tires on Kubota rims and another wore out pair of diamonds on MF 2745 rims. The rims are the same as a 7080 and fit perfectly.
AC7060IL
Posted: 23 Dec 2017 at 7:09am |
Calvin, your AC 220 looks awesome! Does it's rear duals have Mexican hat centers? |
Posted: 23 Dec 2017 at 7:18am |
Steering isn't really an issue on a tractor with power brakes. The improved ride is awesome when you run the air between 15 and 20 psi.
Calvin Schmidt
Posted: 23 Dec 2017 at 7:21am |
Yes it has Mexican Hat duals. It also has a 3500 MK II engine that was factory speced as a "On Highway" and has a factory inline injection pump. Was a standby water pump power unit with 82 hrs when I got it. Just didn't look right without and intercooler. I call it my 220 XT.
Edited by Calvin Schmidt - 23 Dec 2017 at 7:24am |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 23 Dec 2017 at 7:24am |
I love them diamonds also. When I was a kid, a neighbor had a two twenty with em on the front. Looked identical the one Calvin has posted, duals and all. Thought that had a unique factor that was just awesome. If I had the ways and means to do it, every tractor I own would have them. Love the looks of your front tires, too, LBO442. Darrel
Tim (Cent.WI)
Posted: 25 Dec 2017 at 12:14pm |
Are the only rims that work on the turf tires the factory ones that came on 7080s?
Calvin Schmidt
Posted: 25 Dec 2017 at 2:36pm |
The rims on my 220 above are from a MF 2745. Rims were vendor supplied
Adam Stratton
Posted: 27 Dec 2017 at 5:19pm |
I've got 2 pair, both are mismatched and both were on combine rear axles, one set of 6 bolt 1 set of 8 bolts that have split rims. I would take $250 for a pair if you're interested I can send pics, located in SWMO.
Dkienzle
Joined: 22 Feb 2013 Location: Central IA Points: 194 |
Posted: 27 Dec 2017 at 9:32pm |
I agree with victoryallis, the look great and ride awesome, but the steering is terrible especially in worked ground they just slide. We took ours off our 7080 and put a 4 rib on it.
