220 fender head lights
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 220 fender head lights
    Posted: 18 May 2025 at 7:53pm
Would anyone happen to have a couple
of fender headlights that has the GE letters
in the lens,doing a restore and need 2.
I got a couple from a website that had a picture
of them with GE in the lens but that wasn't what I got.
Thanks.
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:11am
I will go check, did have a few of them
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 12 minutes ago at 8:46am
NAPA can cross reference the number.  Replace all 4 so they match.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 14 minutes ago at 3:44pm
If you have a light with the triangle in the middle of the lense and has a G in the middle of the triangle, that is a GUIDE light... A-C used the Guide light assemblies in the productions of their tractors.
Below are a set of lights on a 170
 https://www.allischalmers.com/forum/uploads/242/right_left_lights.jpg
First light is a 4410 back-up light produced by Guide, lots of fluting in the glass.Was also used as a rear work light.
Second light is a GE H7610 halogen 50 watt. If you use these lights, I suggest to either put them on a seperate toggle switch or control them thru relays from the light switch. I smoked a good light switch because I had 3 Halogens on the switch. I put in a toggle switch for them and that has worked very good for me.
Third light looks original to the tractor, It is a Guide 4411 35 watt 'utility'. Dealer parts book calls it 'Road headlight',  part number 230232  .
Forth light surprised me when taking the light out, It turned out to be a GE 35 watt rear tail light/ red light #4409 4tractor6.  Parts book labels the sealed beam as #235583
  As for the field/work light, think the number on that was 4406.  Allis had a part number of 239804 for the sealed beam field light.
  I would put the larger fluted lights in instead of the multiples, just seamed brighter to me.
 Years ago I use to have a list of manufactures and number to identify what light would cross over but can't find that list anymore.
Edited by JC-WI - 15 hours 10 minutes ago at 3:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 5 minutes ago at 6:53pm
We are pretty sure these have the number 4406 on them as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 1 minutes ago at 6:57pm
This what I have and want 2 of the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 43 minutes ago at 7:15pm
I have some NIB GE 4411 lights and a few of then loose.
