220 engine swap |
Post Reply |
Agcosucks
Bronze Level Joined: 17 Aug 2022 Location: Missouri Points: 9 |
Posted: 18 Mar 2024 at 9:14pm |
Opinions on swapping a 7080 motor into a 220?
Dkranawetter
Bronze Level Joined: 08 Feb 2018 Location: Misouri Points: 12 |
Good luck champ, back in my day we didn’t take good tractors and tear them up for pulling reasons.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3348 |
Just google 220 or 210 Allis and look at the pictures. A bunch. Just look at which way the oil filters point and the intercooler. 3500 vs 670 block. ...and this is the pulling forum...only issue is lower radiator hose...fan...
Agcosucks
The 7080 motor is going into my 220 puller. I know the blocks are cast different but it should bolt up the same I assume?
tbran
Yes, as stated IF you are talking complete swap, the location of lower radiator hose and the 220 has a hyd drive pump set up intact. If you have intentions of a front plate swap for a different pump you have a lot of fabrication anyway. The 7080 has the preferred counterbalanced crank and the ability to run an inline pump w/o a harrison style drive as the pump hits the block on the 220 w/o relocation.
Kevin210
Silver Level Joined: 08 Oct 2018 Location: Indiana Points: 383 |
It's a LOT of work,I put an MK II 3700 irragation
motor in my 210,yes it can be done,yes the block will bolt up to the bell housing,however If I can remember some of things I had to doIt's like one step forward and 2 steps back. I'm not familiar with the 7080 engine,but if you keep the hydraulic pump for the 220 you will more than likely run into issues there because if I remember right the front plate on the 7080 wont work for the 220 hydraulic pump,and if you try to use the 220 front plate you will have to work on it because the 3500 and 3700 oil pumps are made different and the 220 plate hits the pump..You can get around water pump and radiator not being on same side but you will have to do some crazy plumbing there to get hooked up and the upper radiator hose will be an issuse too. And probably some issues with the turbo and air intake pipe.. These are just a few of things you will have to figure out that I can remember off the top my head,oh,you may have to cut the hood some on the intake side as it hits the hood there,good luck and it will take a lot of time,it's not as simple as you might think but can be done... Sorry to be so long... |
Kevin210
Have you started your project yet,curious to see how things are going.
Post Reply | |
